Plotting to PDF with tolerance.
john.p.addy
Message 1 of 17
john.p.addy
I'm kind of confused and I can't figure out why this is doing what it is doing.  Its on the same layer and its the same color and everything is set up to be in Dim style under "Bylayer".  It still keeps coming out like this.
Thank you,
John Addy
Electrical Engineering Tech.
Department of Defense
Replies (16)
Message 2 of 17
pendean
Community Legend
Community Legend
@john.p.addy So what is it supposed to look like exactly? You show us only one of two views.
Or is it just the "bolded" appearance of those symbols because they are a different TTF font or have an LWEIGHT setting of "bold" setting not present in the adjacent text?
Message 3 of 17
john.p.addy
yes the boldness of the M in the circle and the o with the + in it should be the same as the other text
Thank you,
John Addy
Message 4 of 17
pendean
Community Legend
Community Legend
@john.p.addy Did you rule out the possibly causes in the second sentence of my first reply yet?
Message 5 of 17
john.p.addy
yes it might be because of the style of font but i don't know how to change that because you can't explode it.
Thank you,
John Addy
Message 6 of 17
pendean
Community Legend
Community Legend
@john.p.addy You can edit blocks with BEDIT command, REFEDIT command, and if those are attributes you can also use EATTEDIT command.
And STYLE command if and only if those custom text objects are defined there too.
You are welcome to share your actual DWG file here too for others to examine.
Message 7 of 17
john.p.addy
Ok let me try to use those.  I'm fairly new to Tolerances an don't know much about them and how they are created
Thank you,
John Addy
Message 8 of 17
john.p.addy
Neither of those commands worked.  Here is a copy
Thank you,
John Addy
Message 9 of 17
paullimapa
It'll work if you modify the Monochrome.ctb's Red color and designate lineweight there to be 0.09mm (attached ctb)
Paul Li
IT Specialist
@The Office
Message 10 of 17
john.p.addy
This is what mine says when I go there.
Thank you,
John Addy
Message 11 of 17
AllenJessup
If you don't want to  edit the Lineweight for the Red color. Change the text color to anything you want and assign the Lineweight to that color.
Allen Jessup
CAD Manager - Designer
Message 12 of 17
john.p.addy
I get what you are saying but did you test that when printing AutoCAD PDF ( high quality ) when you to a plot review that it isn't bold like it is on my end.
Thank you,
John Addy
Message 13 of 17
AllenJessup
I didn't do a plot. Your post 10 in reply to @paullimapa made it seem like you didn't want to change the Lineweight in your CTB. I was providing an alternative.
Allen Jessup
Message 14 of 17
paullimapa
This is why I included in my previous reply message the attached zip file with the Monochrome - Modified. ctb all done for you
To install this ctb in AutoCAD, enter command:
STYLESMANAGER
Then Open the contents of the Zip file and drag+drop the ctb into the Windows Explorer window that just opened.
Enter the PLOT command again and now you should be able to select that ctb like I did.
Paul Li
IT Specialist
@The Office
Message 15 of 17
john.p.addy
OK I'M SORRY I DID NOT EVEN NOTICE THE .ZIP FILE.  I WILL TRY IT THIS MORNING.
Thank you,
John Addy
Message 16 of 17
john.p.addy
THANK YOU,  THAT WORKED.
Thank you,
John Addy
Message 17 of 17
paullimapa
You are welcome…cheers!!!
Paul Li
IT Specialist
@The Office
