Plotting several layouts while saving paper from the plotter roll
I'm trying to plot several A2 format layouts with our plotter, which has a 36 in roll, while trying to save as much paper as possible. Is there a way to tile several layouts to fit the width of the roll and plot them? As well as I tried to fit several A3 formats to the width of the roll?
RobDraw
I don't think it is possible to do that directly from AutoCAD but if you plot PDFs, you can probably do it with those.
Rob
GrantsPirate
Look in the owners manual for your plotter for 'Nest', not all of them have that option.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
john.vellek
Hi @Anonymous,
There is nothing in AutoCAD that tiles prints on a sheet. If your print driver allows nesting or tiling you might able to select that option in the driver. Another alternative is to create one layout in a new drawing that combines all your other layouts  into it. I have done this using xrefs before and it works quite well.
John Vellek
john.vellek
Hi @Anonymous
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
