Plotting puzzle
Plotting puzzle
Plotting puzzle
I am plotting from a layout tab. There are 4 viewports on the tab. Two of them contain PDF images. The image in one of these two viewports will not display in print preview. I have confirmed that no relevant layers have NoPlot turned on and are all unfrozen. I deleted the viewport and made a new one. This had no effect. The image appears when the page prints to either PDF or paper. Why would the image not appear in print preview?
natasha.l
Hello @Anonymous,
Please review the Layer icons in your Layer Properties Manager to make sure they are visible.
Also, check the Inserted PDF settings, right-click "Properties" review  "Layer", "Image Adjust" & "Misc". To verify the items layer properties & visibility.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
natasha.l
Hello @Anonymous,
Just checking in with you, hope you were able to resolve this.
Please remember to "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
imadHabash
make sure that you're NOT using Defpoints layer, also pick inside your viewport ( to make it active ) then type Layer command to check your layer status from the layer manager .
Imad Habash
