Plotting problems
Plotting problems
Plotting problems
I have a set of drawing in one CAD file with several tabs for different sheets. I had it it set to plot in PS 1:1. Was working but not the scale to plot is 3/32" and I can't change it back to 1:1. It keeps reverting back to the 3/32 scale. What is up with that? When I do a plot view it looks fine but when it prints to a pdf I see all these letters & numbers as if there is something an object in PS but doesn't show in preview.
reykosun21
Can you add an picture with the plot configuration and another one with the final result (pdf file)?
Or the file itself if it is not a problem (maybe email to me).
Keep in touch!
[cid:56e784d9-bcfe-4354-bdbb-0c504e42b989]
thanks
Here you go. Thanks.
so I got the plotting scale back to 1:1 by using scaleedit and moving it up to number 1 spot. When I plot to my regular plotter I comes out as it should. But when I plot to pdf using sheet set manager I see all these huge lines and letters that are not in the drawing. Any idea why that is?
so I think I know what is causing the problem just don't know how to fix. It looks look my detail marker text when plotted to a pdf is blown up very large and outside the circle. It's an annotative block that not working correct when plotted to a pdf. Any idea how to fix?
