Plotting problems
Plotting problems
No aplicable
I have a set of drawing in one CAD file with several tabs for different sheets. I had it it set to plot in PS 1:1. Was working but not the scale to plot is 3/32" and I can't change it back to 1:1. It keeps reverting back to the 3/32 scale. What is up with that? When I do a plot view it looks fine but when it prints to a pdf I see all these letters & numbers as if there is something an object in PS but doesn't show in preview.
0 Me gusta
Responder
417 Vistas
6 Respuestas
Respuestas (6)
reykosun21
Can you add an picture with the plot configuration and another one with the final result (pdf file)?
Or the file itself if it is not a problem (maybe email to me).
Keep in touch!
0 Me gusta
No aplicable
[cid:56e784d9-bcfe-4354-bdbb-0c504e42b989]
0 Me gusta
No aplicable
thanks
0 Me gusta
No aplicable
Here you go. Thanks.
0 Me gusta
No aplicable
so I got the plotting scale back to 1:1 by using scaleedit and moving it up to number 1 spot. When I plot to my regular plotter I comes out as it should. But when I plot to pdf using sheet set manager I see all these huge lines and letters that are not in the drawing. Any idea why that is?
0 Me gusta
No aplicable
so I think I know what is causing the problem just don't know how to fix. It looks look my detail marker text when plotted to a pdf is blown up very large and outside the circle. It's an annotative block that not working correct when plotted to a pdf. Any idea how to fix?
0 Me gusta
