AutoCAD Forum
plotting problems
2 REPLIES 2
237 Views, 2 Replies
plotting problems
The scale in plot does not make sense, the only scale that fits the paper is 1:1, which would be impossible considering my plans are over 50 feet. If I choose a smalller scale like 1/4" = 1' then it is tiny. Does anybody know what I'm doing wrong?
2 REPLIES 2
BeKirra
Sorry I don't know your drafting skill level.
I noticed that your viewport size is 0'-10 7/16" x 0'-8". To fit the plan to this viewport the scale has to be set to smaller than 1:1.
In your case it would be better if you set the scale to 1/8" = 1'-0".
BTW What size of the paper you wish to plot? If it can be a larger size you can strech the viewport to suit.
        I am not familiar with imperial units so don't know if the scale factor of 1/8" = 1'-0" is proper.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
pendean
You want to print a 53foot x 47foot house plan on 11x17 and you want 1:1 scale?
1/8" fits fine (Layout2), 1/4: is too big (Layout1) for 11x167, try a larger sheet size (Layout3).
AutoCAD Inside the Factory
