AutoCAD Forum
Plotting or Publishing via the Sheet Set Manager don't work
7 REPLIES 7
Message 1 of 8
cyberflow
2066 Views, 7 Replies
cyberflow
Hi there,
I'm trying to incorporate in my new workplace the Sheet Set in our plan production.
But one of the powerfull thing of the SSM is to publish multiple (or single) sheets at a time.
Well, i tryed it since a few months in and out publishing via the style sheet on the sheet set  template i'm building and it doesn't print.
The publishing icon in the status bar of civil 3d 2012 keeps on going for ever !!! (Even when i cancel the job, it doesn't stop the icone, like it's jamed)
I searched on the web and everywhere and couldn't really find solutions.
Does someone encountered this problem ?
Any solutions ?
Btw, even if i pass by a drawing that isnt in the SSM and choose several layouts to publish it does the same thing too.
I use to do this on a 2008 version of Autocad.
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
Hi there,
Any solutions ?
Frank Freitas
LinkedIn
7 REPLIES 7
Message 2 of 8
pendean
in reply to: cyberflow
pendean
Community Legend
Community Legend
Is background publishing turn on? kill it.
Are you using pagesetups that work with your chosen output device?
What if you publish to PDF or DWF as a test (options are on the PULBISH pop-up)?
Message 3 of 8
cyberflow
in reply to: pendean
cyberflow
Yes, background is active since all the publishing is doing by background.
How do i kill it ? (You mean deactivate ? Or kill it via CTRL+ALT+DEL ?)
My page setups usually works with Adobe PDF proprely.
Did it with the Plotting function and came out perfect.
Tryed out Publish to PDF and does the same thing (I can see the publishing icon working, but nothing happens)
Frank Freitas
LinkedIn
Frank Freitas
LinkedIn
Message 4 of 8
dmfrazier
dmfrazier
To "kill" background plotting means to turn off that feature (setting) in AutoCAD:
Tools (menu)
Options
Plot & Publish tab
Uncheck both background processing options.
-OR, on the commandline:
setvar BACKGROUNDPLOT 0
-OR, copy to commandline:
(command "setvar" "BACKGROUNDPLOT" 0)
This option has caused problems for years.
Tools (menu)
Options
Plot & Publish tab
Message 5 of 8
pendean
pendean
Community Legend
Community Legend
Always turn it off: you never want it to run in the background, Windows is not really ready for that ability (poorly implemented).
Message 6 of 8
cyberflow
cyberflow
Curious problem.
Were i worked before we had Windows XP Pc's with Autocad 2008 and the publishing fuction worked like a charm !
I guess windows 7 isn't ready for this.
Frank Freitas
LinkedIn
Curious problem.
Frank Freitas
LinkedIn
Message 7 of 8
mgalicki
mgalicki
I have an issue while in Sheet Set Manager, I set up my page setups & they are in the list of Publish Over rides.
But I can't add one that uses a window?
Any help on this?
Thank you
Everything in existence was first an Idea
Autodesk Plant 3D Premium 2019
Autodesk MEP 2019
HP 3.2 Ghz CPU 16 ram
1TB 7200 rpm SATA 6Gb/s hard drive
2GB DDR3 NVIDIA GeForce GTX 680ti
HP 2311x 23" LED Monitor
Any help on this?
Thank you
Autodesk MEP 2019
Message 8 of 8
pendean
in reply to: mgalicki
pendean
Community Legend
Community Legend
Post a screenshot please.
AutoCAD Inside the Factory
