Plotting mapped object shadows
Chris_Baze
Chris_Baze
I have a sheet with realistic visual style, a sun, and shadows in AutoCAD 2020. The plot and plot preview will not show Mapped Object Shadows. When I change the shadow display to Ground shadows, they do plot. I found an old thread titled "Plotting to PDF with shadows and no face style" where someone is having a similar issue. @Alfred.NESWADBA found that once a .CTB plot style is applied, the shadows will no longer work even if the .CTB is turned off. I am having this issue now, I can not get AutoCAD to plot with mapped object shadows and a custom .ctb was applied in the past. Is there any way to fix this?
imadHabash
HI,
i suggest to check your hardware acceleration is ON from GRAPHICSCONFIG command , any changes ?
Imad Habash
Chris_Baze
Already on
Alfred.NESWADBA
please show a link to the other thread you mentioned.
Also please upload the dwg-file + the CTB- file + let us know your version of AutoCAD.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Chris_Baze
I cannot post the files, but it's AutoCAD 2020 and the old thread is here: https://forums.autodesk.com/t5/autocad-forum/plotting-to-pdf-with-shadows-and-no-face-style/td-p/430...
Alfred.NESWADBA
Well, hard to compare 2012 with current version of AutoCAD.
Currently it's hard to show the shadow in hidden-line visual style ... and when you succeeded with this ... shadows are turned of when you start command _PLOT (even without CTB assigned to the layout).
So you'll need to define a different visual style (a rendered one), with white walls to get a result close to your wish.
Sorry to not have a better idea, maybe someone else can help more with this.
- alfred -
Alfred NESWADBA
