Plotting issues
Plotting issues
Plotting issues
When I insert an image in my .dwg it comes up as a grid.
Alfred.NESWADBA
The first thought ... this image contains a grid pattern? 😉
Well, what happens when:
  • you zoom more close to a part of that image?
  • you turn off hardware acceleration (command _GRAPHICSCONFIG)
  • you make sure to set the visual style to 2D-Wireframe
You might upload the dwg-file + the image so we can take a look into it.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Thanks, the GRAPHICSCONFIG solved the probem
Alfred.NESWADBA
Great!
If you have small sized dwg-files, only 2D then letting hw-acceleration off is OK.
Otherwise you might look for graphic card driver updates to get your graphi card working better together with AutoCAD. >>>here<<< you can find tested drivers.
- alfred -
Alfred NESWADBA
