Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Plot to folder of drawing
dvrVSNMW
dvrVSNMW
I'd like to plot my PDF's to the location of the drawing I'm working in.
Is that possible?
Now I have to search a while and click a lot of folder to find the correct map.
I know that I can set up a specific folder for all the drawings but that is not a good option. I'd like to save the PDF in the exact same map of the DWG I'm working in.
If I click on "OK" now, it opens the previous folder I have saved a file in. Which is almost never the case.
I'd like to open the folder where the DWG is located. Can I set this up?
D.
dvrVSNMW
I found a little shorter route, not the best but already faster.
If I type "PLOTtofilepath" before I'm going to plot. I have the correct map.
Is there a way that this goes automatically? For example. If I enter CTRL+P or if I click the printer logo, this "PLOTtofilepath" automatically loads?
D.
cadffm
>>"Is there a way that this goes automatically?"
Yes
>>"For example. If I enter CTRL+P"
Edit your CTRL+P shortcut macro
>>"or if I click the printer logo"
Edit your 'printer logo' button
Way to edit your customization user interface file .cuix
Command: CUI
CTRL+P, search your Shortcut and edit the macro, add (command "_PlotToFilePath" (getvar "DWGPREFIX")) ;
between ^C^C and _plot
"printer logo", which one?
search the button and edit the macro, add (command "_PlotToFilePath" (getvar "DWGPREFIX")) ;
For example: Ribbon tab Output, panel Plot, button plot
or if you are refering to the default QuickToolbar - you have to remove the standard button and
add the usual plot button (id_print or ID_RBN_CMDBTN_PRINT, Ribbon tab Output, panel Plot, button plot)
For SDIusers (SingleDocumentInterface) it is easier, they can use there own acaddoc.lsp
https://help.autodesk.com/view/ACD/2025/ENU/?caas=caas/sfdcarticles/sfdcarticles/how-to-make-autocad...
Sebastian
cadffm
Because of your other post:
Menu macro for toolpalette command tool, toolbar, menu or ribbon buttons, shortcuts, as described
^C^C(command "_.PlotToFilePath" (getvar "DWGPREFIX"));_plot
Sebastian
