Plot to folder of drawing
dvrVSNMW
dvrVSNMW
I'd like to plot my PDF's to the location of the drawing I'm working in.
Is that possible?
Now I have to search a while and click a lot of folder to find the correct map.
I know that I can set up a specific folder for all the drawings but that is not a good option. I'd like to save the PDF in the exact same map of the DWG I'm working in.
If I click on "OK" now, it opens the previous folder I have saved a file in. Which is almost never the case.
I'd like to open the folder where the DWG is located. Can I set this up?
D.
0 Me gusta
Responder
353 Vistas
3 Respuestas
Respuestas (3)
dvrVSNMW
I found a little shorter route, not the best but already faster.
If I type "PLOTtofilepath" before I'm going to plot. I have the correct map.
Is there a way that this goes automatically? For example. If I enter CTRL+P or if I click the printer logo, this "PLOTtofilepath" automatically loads?
D.
0 Me gusta
cadffm
>>"Is there a way that this goes automatically?"
Yes
>>"For example. If I enter CTRL+P"
Edit your CTRL+P shortcut macro
>>"or if I click the printer logo"
Edit your 'printer logo' button
Way to edit your customization user interface file .cuix
Command: CUI
CTRL+P, search your Shortcut and edit the macro, add (command "_PlotToFilePath" (getvar "DWGPREFIX")) ;
between ^C^C and _plot
"printer logo", which one?
search the button and edit the macro, add (command "_PlotToFilePath" (getvar "DWGPREFIX")) ;
For example: Ribbon tab Output, panel Plot, button plot
or if you are refering to the default QuickToolbar - you have to remove the standard button and
add the usual plot button (id_print or ID_RBN_CMDBTN_PRINT, Ribbon tab Output, panel Plot, button plot)
For SDIusers (SingleDocumentInterface) it is easier, they can use there own acaddoc.lsp
https://help.autodesk.com/view/ACD/2025/ENU/?caas=caas/sfdcarticles/sfdcarticles/how-to-make-autocad...
Sebastian
0 Me gusta
cadffm
Because of your other post:
Menu macro for toolpalette command tool, toolbar, menu or ribbon buttons, shortcuts, as described
^C^C(command "_.PlotToFilePath" (getvar "DWGPREFIX"));_plot
Sebastian
0 Me gusta
