Plot style tables in DWG true View
Hello , my drawings is to scale 1/4''=1'  but when I print it out the drawing on the paper is not up to scale.To measure my drawing  I use architectural ruler.
Could you please guide me step by step how to solve my problem?
Thank you.
rkmcswain
Take a few minutes to watch this:
[video]
R.K. McSwain     | CADpanacea | on twitter
hi I am sorry but it was not an answer for my question. I am trying to print. My error occurs after I print. Is it related to configuration ?  I havenot assigned line weight in my drawing. Can you help me plot my drawing on proper scale.
Thank you.
rkmcswain
@Anonymous - you said "my drawings is to scale 1/4''=1' but when I print it out the drawing on the paper is not up to scale"
That means you are not scaling your viewport(s) correctly - which is what the video addresses.
Now you are talking about line weight, but you say again "plot my drawing on proper scale"
I'm confused as to what the actual issue(s) is/are.
Why don't you make a ZIP file containing the .DWG file, and the .PDF that you printed from it, so that we can see the data files.
Thanks.
