Plot raster and vector graphics to PDF
joel.moeller
joel.moeller
Is there away to mix raster and vector graphics in a single viewport? Or a way to place multiple viewports ontop of each other and controling what layers plot in what viewport?
Having text and lines plot as raster makes for hideous results that I can't with good conscience share with anyone.
Alfred.NESWADBA
Yes, if you have a raster file inserted/referenced and vectors from AutoCAD like lines, circles, ... no problem.
Also this is possible, but a bit critical to handle for users not knowing there are 2 or more viewports overlapping each other.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
joel.moeller
Sorry, I was not precise enough in my question. I want to plot point clouds (which by necessity are plots as raster) at the same time as I plot text and other vector graphics.
- alfred -
It'll be tricky, sure, but possibly easier than plotting twice (with changed settings, layers hidden etc. between plots) and combining the result PDFs into one outside of Autocad. How can I set a layer (or object, or type of object) to only plot in a chosen viewport and not in others?
Alfred.NESWADBA
Because of the visual style you need to set to a rendered style.
In one viewport you can only have one visual style enabled, so this seems to bring you to overlapping viewports.
When you are inside a viewport and you start the layer-manager you can use the column "VP-Freeze" to freeze a layer only in the current viewport.
- alfred -
Alfred NESWADBA
