How to install Hatch Patterns
How do I install hatch patterns in ACAD 2014 with Windows 10 OS
pendean
Community Legend
Community Legend
Custom Hatch patterns/ PAT-extension file rules:
1. File name and hatch pattern name must be one and the same.
2. One hatch pattern per file.
3. there must be a single blank line at the end of the definition in the PAT file.
4. The PAT file must be in AutoCAD's search path.This can be any folder, simply add that folder to the search path using OPTIONS command>Files Tab>Support File Search Path.
5. You then find all of these new hatch patterns that you added under the CUSTOM option in HATCH command pop-up (or in the Ribbon).
HTH
Alfred.NESWADBA
Please find this AKN article describing the necessary steps >>>click<<<
Take care, AutoCAD 2014 is not designed to run on Windows 10, every single update of Windows 10 might break it.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
