AutoCAD Forum
Plot preview different of pdf
2 REPLIES 2
4244 Views, 2 Replies
I do a preview of my drawing and all is perfect.  ctb. file is working and linetype/colour is perfect.
But when I print, the fix shows up with diferent linetypes/ticknesses/colours.
Can someone help mt to solve that?
2 REPLIES 2
Alfred.NESWADBA
can you show drawing (and CTB) as well as PDF? (upload it so we can take a look into it)
Also important: which PDF-driver did you use? If not the original AutoCAD one then try it again using "DWG to PDF.pc3"
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Hi Thank you very much.
"DWG to PDF.pc3" worked perfectly.
Many thanks
CM
Virus-free.
www.avast.com
<#DDB4FAA8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
AutoCAD Inside the Factory
