Plot -> Plot scale -> Scale Line weights (not working)
Message 1 of 17
First off let me state that I have been using Autocad for well over a decade, so please read thoroughly before respond with a simple answer.
We have 2 print sizes in our office, a standard D size and a half sized 11x17 standard.  By default its D, and I created a 'half sized' page setup that imports a different setup for a different printer and checks the 'scale lineweight' box as well.
All was working perfectly up until ACAD 2016, when all of a sudden the 'half sized' setup instead of scaling lineweights just reduced them all to zero, when I unclick the 'scale lineweight' box all my lineweights for 11x17 sheet, as one would expect, all the line thinknesses are double.
Now if i keep the 'scale lineweight' box checked and make a PDF instead, the line thicknesses are as they should be, go figure.
I am at a loss for whats causing this to happen, all things being equal the only difference is the ACAD platform itself.  We picked up 2018 and still the same issue.  Now I have a workaround that I have been using since 2016, obviously, but I would rather an answer and so would my boss, as sometimes I forget and print a drawing with no lineweights and have to explain this 'bug' again.
Replies (16)
Message 2 of 17
ceciliabao
Hi Andre,
Welcome to Autodesk forum!
Could you please send me your drawing?
Or could you please describe the line weight used in the drawing?
My email is cecilia.bao@autodesk.com
Best Regards,
Cecilia Bao
Senior QA of AutoCAD for Mac
Message 3 of 17
It happens regardless of the drawing. I dont understand the second question, describe the lineweights used?  I can send the .ctb file but I cant imagine that would do any good.
The .ctb file is the only common denominator, but the problem doesnt lie with the CTB file, it has to do with print driver.  I will reply again when I get to the office.
Message 4 of 17
I got an email from Autodesk ......
The forums answered your question-accept as a solution?
um nope, not a chance......
Message 5 of 17
ceciliabao
Hi Andre,
I cannot reproduce the bug you described. Maybe related on printers used or other settings.
Could you please take a screen shot of your plot dialog (with the settings)? So I can try to reproduce this bug.
If you can send me the ctb file and the drawing/ screenshot , that will help more.
Best Regards,
Cecilia
Cecilia Bao
Message 6 of 17
kadmonkee
create a single page setup with your Standard D size confirm all the settings as required.
create a pdf full size.
send to any printer and choose 11x17 paper size  for 1/2 size prints
check your ctb file and your pmp file that is associated with your Page setup.
it could be each separate drawing may not have the same page setup.
if you create a template for this you can import it into any new drawings, if not already in place.
not all printers are created equal so the drivers will vary in the results.
the PDF is more consistent.
and you only have to manage one page setup, ctb, pmp etc.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 7 of 17
What exactly do you think you are telling me that I dont already know? Not
to sound snotty but yes this is exactly what I did, please reread my post.
Message 8 of 17
kadmonkee
I do not need to reread your post
the simple answer is use the workflow that works for you.
create a pdf full size (this works ) your words.
print to ANY printer at whatever size paper you need
too simple?
your welcome.
thank you
Message 9 of 17
Obviously you do need to reread it, because again you are stating a simple answer/workaround, that does not help. What was the first thing I said?
There is nothing more infuriating than stating clearly that you have a workaround but are looking for another solution and have someone chiming in with a workaround.
Edited by
Discussion_Admin
Message 10 of 17
kadmonkee
ok lets read it together
1. Congratulations for your success in using AutoCAD for more than a decade.
2. you do not need (2) SIZES, create your D size page setup and use a PDF device to make all your prints then print them to any printer
3. a compatibility issue with the new versions of AutoCAD and your Printers drivers is occurring, confirm the latest drivers are installed.
4. A workflow that works, print all your drawings to PDF first, more consistent output.
5. Things arent equal see Note 3.
the solution is simple CHANGE your WORFLOW.
now to your last comment, people are here to help, they may provide you with a solution you are not aware of.
however you take their advice is completely up to you.
but name calling is completely unacceptable and extremely unprofessional.
good luck and maybe there are other forums you should check out to help you with your issues.
thank you
Message 11 of 17
I reported you already and I am no longer giving into your attempts to make
me angry. Again I say, please go away, I do not want your responses,
Have a day.
Edited by
Discussion_Admin
Message 12 of 17
kadmonkee
my previous attempts to help were genuine.
Edited by
Discussion_Admin
thank you
Message 13 of 17
Hi Andre,
I printed out two copies. One is D size and the other is half D size. Both of them checked scale line weight. The results are correct.
Here are the steps how I created them. Could you please point out the differences from your steps? So that I can reproduce the issue.
1. I create a pagesetup with Size D 22X34 inches in layout , and create several lines with different line weight.
2. print out the layout with following settings.
3. copy the layout, and apply a new page setup with half size D 11X17 inches. The scale is 1:2 and scale lineweight is checked.
4. print out with following settings
5. Compare the printed results.
The half size D paper printed half width lineweight.
Best Regards,
Cecilia
Message 14 of 17
Thank you for your response.   Unfortunately I need to get some work done but I will be back to address this later on today.  Thanks again.
Edited by
Discussion_Admin
Message 15 of 17
Discussion_Admin
Everyone
Please remember these are professional forums and as such deserve a professional decorum when participating.
Discussion_Admin
Message 16 of 17
I believe I am having the same issue with AutoCAD Map 3D 2017. I have noticed when I change paper size the plot scale automatically adjust to inches from the metric mm. Even after I adjust the plot back to mm, the plotted drawings appear to be scaled to a much smaller amount causing the lines to be so faint they do not plot. My assumption is that they are being plotted at 1=50.8 inches instead of 1=2 mm, an issue I never had while using previous versions of AutoCAD.
Message 17 of 17
Tekcon13
I suspect cybuls_c is on the right track.
We work mainly in metric, and occasionally use imperial sheet sizes.  We plot using lineweights, not colour, and OOTB monochrome.ctb.
If we plot a metric drawing reduced down to an imperial 11x17 sheet with the lineweights scaled, ALL the lines appear exremely fine. (Image #1)
If we plot a metric drawing reduced to a metric A3 sheet with the lineweights scaled, the lines appear properly scaled. (Image #3)
I also used the PDF workaround suggested by others in this topic, which produced acceptable results.  (Image#2)Plot-Scaling-Lineweights2.png
