Error message: AutoCAD Cannot Continue
Message 1 of 27
Hi
I have the same problem that can be fixed by manually upgrading virtual memory.
The question is, I have a new Asus ROG 16MB RAM, I7 HQ, with a 1070 GTX NVIDIA
Why is this happening now? Could this be a virus eating up my memory?
I doesnt make sense, since it didn't happen before and frankly my computer is quite powerful
Replies (26)
Message 2 of 27
john.vellek
Hi @Anonymous,
I'm sorry that you are seeing this error.
Typically this message results from a graphics card that is not certified to work with AutoCAD. Another possibility is corruption in your operating system.
There are few things you can try.
  • Turn off hardware acceleration in GRAPHICSCONFIG.
  • Check for a more current driver for your graphics card.
  • Create a new user on your computer (administrator) and log on with that account to see if the behavior continues.
Please try these steps and let me know the results.
John Vellek
Message 3 of 27
Hi john
Thanks for answering
I have already deactivated mi graphic card and this is still happening.
Only by increasing my virtual memory the problem seems to have a certain solution.
If ever the operative system is corrupted, what can I do to fix it?
Message 4 of 27
john.vellek
HI @Anonymous,
Did you also look for a newer graphics card driver?
To fix a corrupt OS, I would wipe the drive and reinstall everything. This is obviously a painful process but if it eliminates errors and crashes it is well worth the time.
John Vellek
Message 5 of 27
rkmcswain
When does the crash happen? With certain drawings? Certain SIZED drawings? When doing a certain command, such as 3DORBIT? When printing? Seemingly random times?
As stated earlier, make sure you have the correct driver for your display adapter:
http://usa.autodesk.com/adsk/servlet/syscert/card?siteID=123112&catID=18254205&id=18844534&product=1...
R.K. McSwain     | CADpanacea | on twitter
Message 6 of 27
When I wipe my drive, can I select the option "keep my files" or that's not gonna do it?
I don't think is the graphic card'a driver since when I deactivate it the problem remains
Message 7 of 27
john.vellek
If you are going to wipe the drive I would personally suggest that you make a good backup of all your data first and don't rely on any "automatic" save of the files.
Please tell me your OS, make and model of your graphics card, and your AutoCAD version.   A new driver might fix all of this and save hours of rebuilding your system.
John Vellek
Message 8 of 27
Hi John
Is a laptop, Asus ROG strix. Intel I7 6600 HQ, 16 GB ram, 256 GB SSD and a 1 TB HD.
It runs under Windows 10
The graphic card is a 1070 GTX NVIDIA 4GB
Thanks !
Message 9 of 27
john.vellek
Hi @Anonymous,
This appears to be the most current driver. Please install and let me know if it improves the issue.
John Vellek
Message 10 of 27
Hi John
I've successfully installed the drivers and it didn't fix t the issue.
In any case, as I said before it works but manually upgrading the virtual memory. Does this give you a hint of what could be the culprit?
Also, by upgrading the virtual memory, am I putting my laptop in danger?
Thanks in advance
Message 11 of 27
john.vellek
Hi @Anonymous,
Since you have 16 GB of RAM, I am surprised that you find it necessary to increase the memory. I don't believe that this should cause any issues with your system but I am concerned as to why it would be necessary. It sounds as if you are possibly out of page space.  Have you cleared your TEMP folder and any other cache?  Are you out of disk space?
John Vellek
Message 12 of 27
Exactly, that's why I'm writing here.
I have plenty of space in my SSD. 130 GB.
Are you aware of any virus or malware that can be causing this? Do you think this could be the actual reason?
Message 13 of 27
rkmcswain
You have ignored a lot of questions asked by people trying to help. Can you please address them for us to help you?
(all of the Q in post 5, and the next to last Q in post 11)
Message 14 of 27
Hi rkmscwain, I'm sorry I'm not seeing all of the posts actually.
I've only seen one question asking about 3D orbit, I do not use this command. The crash happens only after 30 seconds charging practically any file. I've only found two exceptions.
The problem seems to get bigger since now it crashes also when I expand the virtual memory
I don't know what to do. I've tried almost everything and I can't afford to wipe all my files since I don't have an external drive and not a lot of time
Thanks a lot for replying
Message 15 of 27
rkmcswain
What does that mean exactly? In 99% of cases, you should never have to touch your virtual memory (which means the swap space to me) - especially since you have 16GB of RAM.
Message 16 of 27
rkmcswain
1. Have you cleared your TEMP folder
2. When does the crash happen? With certain drawings? Certain SIZED drawings? When doing a certain command, such as 3DORBIT? When printing? Seemingly random times?
Message 17 of 27
john.vellek
Hi @Anonymous,
One more question. What is your version of AutoCAD and do you have it fully patched with hotfixes and updates?
John Vellek
Message 18 of 27
Hi
Yes I have cleared my temp files. The size of the file has nothing to with it I guess since I happened with a 130 KB proyect and with a 2MB proyect as well. It seem quite random I guess, but I can work for no longuer than 4 minutes
I have AutoCAD 2017 and also the 2014 version. I happens with both of them. How can I get patches or hotfixes?
Thanks to both of you
Message 19 of 27
john.vellek
Hi @Anonymous,
You can use the Autodesk Desktop App to find updates.  Also, if you go to your account management page from inside of AutoCAD (top rt corner) you should be able to find them there too.
John Vellek
Message 20 of 27
rkmcswain
Go to https://manage.autodesk.com/
Log in.
Find your product.
Click Updates & Add-Ons
Download.
Install.
Before you do updates, log out, and log in as a new user (one that has never logged on to this PC). If it still crashes in the same manner, this pretty much rules out a user profile issue, since you will be starting with a new user profile. If it does not crash in this configuration, then RESET YOUR SETTINGS. If neither of these help, then it's probably an issue with your data files.
