Plot Custom Properties Error
ali.derman
ali.derman
I have Autocad 2013-2015 products. When plot on drawing, I select my printer and than printer custom settings , Autocad products give fatal error and closing.
I use windows 10 Pro 64-bit operating system.  I attached error screen shot.
I look forward to hearing solution from you as soon as possible.
Sincerely,
Ali Osman DERMAN
Alfred.NESWADBA
HP does not provide drivers for the 10xx plotters for Windows 10 and AutoCAD seems to have issues using this drivers (>>>discussed here<<<)
You'll probably have to create a PC3 using the HP DesignJet 755 (or a global HPGL2 plotter) using the "add a plotter wizard" within PLOTTERMANAGER.
Be careful, the colors might differ.
Sorry, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
