AutoCAD Forum
Plot area when publishing to PDF
12 REPLIES 12
Message 1 of 13
prousseauCQJ6U
1942 Views, 12 Replies
prousseauCQJ6U
Hi all,
When creating a page setup, you get to choose the "plot Area" like so:Untitled.png
However, when publishing to pdf with no assigned page setups, the default behavior seems to be to plot to Extents. I would like to change the default behavior so that publishing to PDF only plots the layout area, as I tend to move unneeded Paperspace annotations out of view.
is there any way to change the plot area when publishing to PDF? The DWG to PDF.pc3 file only seems to control line overwriting and other rendering settings so I don't know where to look for.
Hi all,
Tags (3)
12 REPLIES 12
Message 2 of 13
ara_neresesian
HI
change setting on option to.
for new layout it will print layout not last successful .
good luck
HI
good luck
Message 3 of 13
prousseauCQJ6U
That's not quite what I'm looking for, but thanks for the input!
Message 4 of 13
maratovich
in reply to: prousseauCQJ6U
maratovich
No problems.
1. First you need to find the title blocks.
2. Then specify the print area with a window for each title block.
3. Save the settings for each layout.
All this can be done automatically for all layouts -
Revers
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
No problems.
Revers
www.kdmsoft.net
Message 5 of 13
prousseauCQJ6U
in reply to: maratovich
prousseauCQJ6U
Hmm.. I don't think that's quite what I'm looking for.
Message 6 of 13
maratovich
maratovich
This is just what you need.
You have different title blocks.
You want the correct paper size (PDF) to be automatically set
And print the desired area in the drawing.
This is all done automatically.
Give an example of your .dwg file.
www.kdmsoft.net
www.kdmsoft.net
Message 7 of 13
prousseauCQJ6U
prousseauCQJ6U
I just want to know if there's a way to modify the plot area when publishing to PDF (either when AutoPublishing or when using the publish command, or when publishing to PDF through a sheet set.)
My problem is simple: I have moved a Paperspace table out of the paperspace area (the white background representing the paper) in one of my layouts, and now, i can't simply publish to PDF because, if I do so, the plot area is shifted on that particular layout as a result of it defaulting to an Extents plot area.
I know I could use a page setup, but I just wanted to know: is there was a way to modify the default plot area setting when publishing, much like how we can modify it in a page setup (see Original post's first picture).
Hope that cleared things up.
Message 8 of 13
RobDraw
RobDraw
Why don't you use page set-ups? You just might find it solves this issue.
Rob
Rob
Message 9 of 13
prousseauCQJ6U
in reply to: RobDraw
prousseauCQJ6U
Because I am curious to see if publishing's settings can be modified.
Message 10 of 13
RobDraw
RobDraw
Page set-ups are used to modify publish settings.
Rob
Rob
Message 11 of 13
maratovich
maratovich
No.
www.kdmsoft.net
No.
www.kdmsoft.net
Message 12 of 13
RobDraw
RobDraw
No.
Actually the answer is yes. Named page set-ups.
Rob
No.
Rob
Message 13 of 13
prousseauCQJ6U
prousseauCQJ6U
After a bit of testing here's what I found:
Selecting publish to PDF only tells AutoCAD to use the DWG to PDF.pc3 plotter. At first I thought there was  a variable assigned to "Publish to PDF" somewhere telling AutoCAD to default to a specific plot area but as it turns out, when publishing with no assigned page setups, the plot area is controlled by each layout's indivual page setup (the ones whose names are prefixed and suffixed with asterisk symbols).
Therefore, I can hit "Apply to layout" button after setting the plot area to Layout
And the PDF turns out fine whichever way I publish it. I could also modify our company's DWT file accordignly so that the plot area is more suitable. I know this thread might make me sound a bit picky, but why would the "publish to PDF" option exist if you couldnt control the plot Area? That would render features like AutoPublish completely useless, as they can't use page setups. Guess it makes sense now.
Hope I haven't been too vague, sorry for the confusion, my understanding was a bit off. And thanks for the input.
AutoCAD Inside the Factory
