Pline command draws rectangle instead of polyline
Guys,
need some help here.
I need to overlay the coordinates of installed watermain over an existing watermain drawing.
I have the coordinates, as I enter them the first time, I get a line drawn, as expected.
The second attempt, draws a rectangle, which makes no sense to me at all.
Any clue as to what to do in order to solve this?
cadffm
1. It IS a polyline!
Select the object and run command LIST or see the content in your properties palette (ctrl+1)
2. Your setting for polyline width is set to higher than 0
Set it back to zero
https://help.autodesk.com/view/ACD/2020/ENU/?guid=GUID-35EEB892-15C9-442F-847D-2F4DC52E9690
3. Your current view is not 90°c to the current working plane(ucs)
OR FILLMODE is set to 0 (=off)
You should test 1), check the 3) and at last change the default plinewid to 0
Sebastian
