Hi, big problem about the printed lineweight from Autocad 2016.
The lineweight are not respect on Canon and HP printer models.
We have to do a .pdf to remedy but the Customer dont want to do that.
All the firmware are up to date on the printer as well AutoCAD 2016.
Thanks in advance.
Steph Demers
Printer technician
Thanks in advance.
Steph Demers
Printer technician
Solved by Alfred.NESWADBA. Go to Solution.
Devices can't ignore the lineweights, so I guess it has more to do with PC3 settings or CTB/STB settings or the setting for lineweights in the plot dialog.
Also make sure you are plotting 1:1 as scale setting in the plot-dialog.
The easiest way to check that is the setting you use for creating a PDF ==> only change the driver to your HP or Canon driver, nothing else ==> when you have seen the lineweights in the PDF you should see them now on the devices too.
- alfred -
- alfred -
