Picking / Selecting object in autocad getting very slow.
ravi143ramu
ravi143ramu
While i picking / selecting the object in autocad 2015, it will getting very slow.
Kindly provide solution for this issues.
Ravichandran
Alfred.NESWADBA
First I would make sure that you have installed the latest service pack.
Then I would ask:
  • is that a new situation or a new installation of AutoCAD 2015, if it worked well previously what changed on the system
  • does the same happen in a new file
  • does the same happen if you close the property window (and disable quick-properties if you have them active)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
jayhar
Turn OFF GRAPHICSCONFIG
Change program settings speed up Auto cad  click here
Set the AutoCAD system variable WHIPTHREAD to 3.
Set the AutoCAD system variable LAYOUTREGENCTL to 2.
Set the AutoCAD system variable SELECTIONPREVIEW to 2.
Set the AutoCAD system variable SELECTIONCYCLING to 0.
Set the AutoCAD system variable OSOPTIONS to 6.
Set the AutoCAD system variable SAVEFIDELITY to 0.
Turn off "Full-time CRC Validation" in Options under the Open and Save tab.
Turn off hardware acceleration (GRAPHCISCONFIG command).
Close the Properties palette (CTRL+1).
Set your system's virtual memory to maximum.
Change your Visual Effects to "Adjust for Best Performance."
Reduce the value of the AutoCAD system variable HPMAXLINES.
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
ravi143ramu
Then I would ask:
- alfred -
Thanks for your reply.
I have to picking/ selecting object in autocad 2015 it will be getting very slow, see the below snap for your easy reference.
Kindly provide correct solution.
Thanks and regards,
Ravi
Alfred.NESWADBA
I can't ... you were not answering my questions.
How should I (or anyone else) suggest anything without getting the information's needed to send suggestions?
- alfred -
Alfred NESWADBA
ravi143ramu
Thanks You
Jayhar.M.J
Thanks for your reply,
I have checked here, The exact comment is " Set the AutoCAD system variable SELECTIONPREVIEW to 2".
Thanks and regards,
RavichandranC
rkeckhut
I just tried changing these setting and it made to slow response even worse.
