Selection filter with multi object.
Message 1 of 10
Hi..
I am using the filter object with separately it's will take time to me so, I have trouble to use filter command.
i hove to select multi object select with one time.
Is possible in filter command?
Please advice me...
Please refer below snap..
Thanks in advance.
Sujinkutti.
Replies (9)
Message 2 of 10
SEANT61
Are you trying to select multiple entity types?  In your example; the selection should retrieve entities if they are of type Dimension or Leader.
May your cursor always snap to the location intended.
Message 3 of 10
Yes, i'm trying to multiple entity types.
I need to filter dimension and leader at the same time.
I don't understand how to make like this...
Sujinkutti..
Message 4 of 10
designdistrict7
Hi, Sujinkutti
Select multiple object that you need to select, then right click , from menu choose " select similar" that all.
Message 5 of 10
jayhar
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
watch this video https://autode.sk/2yfVgy5
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Message 6 of 10
HI...
If i using  " select similar" command it will be select all in the drawing. But i need to select particulate selected object only.
Please advice prepare to filter command.
Sujinkutti.
Message 7 of 10
SEANT61
Message 8 of 10
designdistrict7
If you want to do selection in a particular area then do the selection with "SELECTSIMILAR" and deselect (shift-click) the area you don't want. Or try with "QSELECT".
Regards
Message 9 of 10
designdistrict7
Awesome.. 🙂
Message 10 of 10
@SEANT61 wrote:
Hi..
yes it's working now..
Thank you very much for the response..
Thanks and regards.
Sujinkutti.
