Perpsective mode turns on in 3D whenever i Pan
Marcus_GordonLJA2A
Marcus_GordonLJA2A
Community Visitor
Community Visitor
Im not sure how it happened but whenever i pan in 3D, the view automatically turns to 'fly' and perspective mode. No matter what i have tried i cannot fix it. I have tried using the ViewCube and turning perspective to 0. Any other suggestions that could fix this?
BhaskarMurari
@Marcus_GordonLJA2A Can you check this Home View switches to perspective projection in AutoCAD.
Also you try Reset AutoCAD to its default settings. This can resolve unexpected behavior caused by corrupted settings.
imadHabash
Hi and Welcome to AutoCAD Forum,
@Marcus_GordonLJA2A
Would you try to turn on/off hardware acceleration from GRAPHICSCONFIG command and see if any changes.
Imad Habash
BhaskarMurari
@Marcus_GordonLJA2A Was your issue resolved.
manieshkumar.suresh
Issue happening with all drawings
  • Clicking anywhere on the View Cube should reset the coordinates of the view. However, if the View Cube setting 'Zoom to extents after view change' is deselected, then clicking the View Cube will not clear up the behavior.
  • Change the visual mode to Perspective by right-clicking on the ViewCube - then change it back to parallel by either changing to 2D wireframe visual style or right-clicking on the ViewCube.
  • Changing the current visual style to 2DWIREFRAME will fix the issue with the ZOOM command.
  • Right-click on view cube and select ViewCube settings or enter the NAVVCUBE command.
    • Deactivate "Keep scene upright".
Issue is specific to particular file
  • Type SCALELISTEDIT and use "Reset" to reset the scales to imperial or metric
  • Type -PURGE -> regapps -> ENTER -> NO
Maniesh Kumar Suresh
Escalation Lead
If this information was helpful, please use the Accept as Solution function — it helps other users.
lauri_barnhart
Hello, @Marcus_GordonLJA2A,
Just checking in—did the responses shared by @imadHabash or @manieshkumar.suresh help clarify your question? Did you also see the question in @BhaskarMurari's reply?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Lauri | Community Manager
