Performance Issues
Performance Issues
Message 1 of 23
Performance Issues
Hi
Recently I downloaded AutoCad 2017 onto my laptop, but I haven't been able to use it all that much because most of the commands are tiny, for example the Layers Properties menu. The words and window itself are all squished together and even the best magnifying glass doesn't help! Even at that, the program runs very slowly, but I can't understand why. I bought my PC nearly specifically to run this program, keeping all specs in mind for it, but no joy. In the screenshot i have here you can see the issue with font type. PLEASE HELP.
My PC has the following specs:
Windows 10 (64-bit) @ 2.60GHz
8GB RAM
Intel i-7 quad core
NVIDIA GeForce GTX960M w/ 4GB vRAM
Replies (22)
Message 2 of 23
Alfred.NESWADBA
start the Autodesk Desktop App, it shows you that AutoCAD Update 1 is available, install this and the different font sizes in the property dialog and layer dialog are solved.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 23
kennyj
Welcome to the forums, D.Odufaigh!
This is a known issue.  Google "Odd text display within user interface elements in AutoCAD".  There is an update to help, and it has directions on how to adjust your Windows settings to help.
Hope this helps,
Kenny
Message 4 of 23
Thanks, I tried this first after about a week and had no joy, checked again just to be safe and it says its up to date. Any other ideas?
Message 5 of 23
Alfred.NESWADBA
How long did you have Autodesk Desktop App open? Just started and closed? Then no, it does not connect all the time to make sure it does not block your system/processor too much as well as not blocking your internet connection.
Start AutoCAD, start command _ABOUT and show us the screenshot of that dialog, so we can see if Update 1 is installed or not (I guess no, because you would not have that display problems).
- alfred -
Alfred NESWADBA
Message 6 of 23
Thanks Kennyj
I have tried all the settings changes and still no luck. I have the download installed and it is still out of proportion. When I changed both the scaling and resolution, the other icons begin to get bigger, but like in the picture I sent before, the properties window is still all scrunched together. My recommended resolution is 3840 x 2160, and even at that some other applications run smaller than I've seen on other pc's, but nothing compared to AutoCad
Darragh
Message 7 of 23
-alfred-
I had AutoDesk Open for a few minutes but it didn't indicate after that long that an update available. If the update is the "Service Pack 1", then yes I do have it installed, but if there is another one available then that could be the issue.
Darragh
Message 8 of 23
Alfred.NESWADBA
No, it could need hours.
Make sure it is in logged in state and it can connect to Autodesk's server.
No, "Update 1" is different to "Service Pack 1" (and therefor I would like to ask guys at Autodesk what sense that makes to sometimes call it "Update" and the other time call it "Service Pack". It's so .... )
- alfred -
Alfred NESWADBA
Message 9 of 23
Hi
Okay thanks very much, I'll give that a go and keep you posted.
Is there any way to download the update outside of the AutoDesk app? And I was very confused by it for a while with the Service Pack and Update thing, never knew there was actually a difference.
Darragh
Message 10 of 23
braudpat
Hello
Welcome to the Autodesk / AutoCAD Forums !
1) You can download the SP1 for ACAD 2017 from here :
https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-2017-service...
But when I see your ABOUT screen capture, you don't need it !
Because it is already installed ...
2) The 2017.1 comes from the Autodesk Application Manager, so ...
3) The 2017.1 solves some (but not all) display problems with a vertical resolution > 1600 pixels  (for exemple 4K display) !
And the 2017.1 can solve display problems with very high vertical resolution on Win 10 but NOT on Win 8 or Win 7 !!
Regards, Patrice
PS: Sorry for my multiple updates on my message but I had some Internet problems !
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 11 of 23
Alfred.NESWADBA
I have not found one (yet). I do understand your confusion and I don't understand Autodesk why they don't put it to the downloads site (maybe they want to force the users to have the Desktop App installed, not kind at all).
- alfred -
Alfred NESWADBA
Message 12 of 23
Hi
Thanks Patrice, but i have the SP1 downloaded, its the update that I need to download haha.
Darragh
Message 13 of 23
Alfred.NESWADBA
Hi Pat,
@braudpat
SP1 is not Update 1, that are two different things!
- alfred -
Alfred NESWADBA
Message 14 of 23
braudpat
Hello
NOW my previous message is finished and OK (for me) !
Regards, Patrice
Patrice BRAUD
Message 15 of 23
Bit annoying really, but what can you do.
Thanks for your help -alfred-, I'll let you know if it works.
Darragh
Message 16 of 23
amberph
Hi @Anonymous,
Can I know what kind of subscription is your AutoCAD?
If you are on Desktop Subscription, you should be able to see Update 1 on your Autodesk desktop app.
the right update for your problem is  AutoCAD®2017.1 Update.
it should fix your high PPI display issue for many user interface elements, such as command line, layer manager, palettes, etc.
If you are on subscription and still not seeing this update showing on your Autodesk desktop app, you can try to go to: Autodesk Acccount ,to install this update.
thank you.
Peng Hong
Senior Experience Designer
Message 17 of 23
Alfred.NESWADBA
Does that in the opposite mean that customers without subscription don't get updates any more? Is that the reason why the update can't be found in the download section?
(could get an interesting discussion 😉 )
- alfred -
Alfred NESWADBA
Message 18 of 23
Hi
I have a student subscription, or so i believe haha. It's licensed through my college so I assume so.
Checked your link as well and it doesn't show up there. Not too sure whats going on really.
Darragh
Message 19 of 23
dhard
- alfred -
Hi Alfred,
Only customers on a valid form of subscription are currently eligible to receive updates (starting with the 2017.1 Update).  For these customers, the updates can be downloaded via the Autodesk Desktop App, or from the Accounts portal.
We are currently looking into making updates available to students as well.
Thank you.
Debashis Dhar
AutoCAD Test Development
Message 20 of 23
dhard
@Anonymous wrote:
Hi
Darragh
Hello Darragh,
We expect the updates to be available to students in the near future.  Once available, you should be able to install them from the Autodesk Desktop App.
Thank you.
Debashis Dhar
