pdf registration
pdf registration
newsgid
pdf registration
newsgid
Please find attached AutoCAD file 132_1114_0.dwg and Adobe file 132_1114_0.pdf.
The AutoCAD file is correct but when I generate it's plot file using the virtual plotter "dwg to pdf.pc3," the registration is not good.  I am trying to get the .pdf plot centered properly on the sheet.
I use pick "points" between the trim line and the boarder.  And I am not trying to get the trim lines to plot as these are coincident with the edge of the sheet.  I am plotting full scale.
Hope you can help.
Very truly yours,
Sheldon Goodman
[email protected]
tboehler
Just change "plot area" to extents (not window) .   That is all I did.New PDf is attached.  Is that what you are expecting?
pendean
Community Legend
Community Legend
