PDF not centered when printing
Message 1 of 36
I have tried a few of the options in other posts but when I publish to pdf and then print the document is not centered.
I know just enough to create my document and save/print it but can't get the document centered. I usually use 1 of my layouts 95% of the time when I save the file.
The layout has a titleblock that I created
Any help is appreciated.
  • Help
Replies (35)
Message 2 of 36
peterjwinberg
Is the document centered when you view it as a PDF? If so, then this sounds like a print setting and not a publishing issue...
Message 3 of 36
It is not centered in the file
Message 4 of 36
ValdisPriednieks
PDF print is slightly shifted, if You print layout which You have set up for a physical printer. Layout must be set for PDF print.
Message 5 of 36
peterjwinberg
Can you post the file?
Message 6 of 36
Chad.millard
It's been my experience that typically when this happens, there is an object somewhere that it is trying to print.
Mostly, it depends upon your plot settings though.  Are you plotting from Paperspace, or Model?  Extents, layout etc.  If you could upload the file, it would help tremendously.
Message 7 of 36
ValdisPriednieks
For example:
Message 8 of 36
ValdisPriednieks
Layout is set for my physical printer. When I export it to pdf, all is shifted in pdf file.
Message 9 of 36
ValdisPriednieks
For pdf printing layout must be set for pdf.
Message 10 of 36
tboehler
To make it centered in the PDF simply choose "extents" for plot area and check "center the plot" under plot offset.  Only those 2 things.
Do you want it centered on the page?  or just Vertically with room for binding on the left?
The attached is centered on the page.
Message 11 of 36
Scaling small is the layout I publish from
Message 12 of 36
Scaling Small is the layout I publish from
Message 13 of 36
ValdisPriednieks
It doesn't matter what I want. It is a fact that layout setted for a physical printer then exported to pdf is shifted.
Topic starter asked about this.
Message 14 of 36
tboehler
I answered the wrong post earlier.  lol.
Message 15 of 36
ValdisPriednieks
I see layout is set for TOSHIBA printer. You must set the layout to a pdf printer.
Message 16 of 36
I go to file, publish select the layout I want to send to pdf and those are not options.
Message 17 of 36
I don't see that as an option.
Where exactly is that?
I go to file>publish>select the layout
Is it under page setup?
Message 18 of 36
tboehler
File
Page Setup Manager
Select layout
Modify
Or right click on the layout tab and select "page setup manager"
Before you publish.
Sorry - I use PLOT 98% of the time - then i see those options right o way.
Message 19 of 36
ValdisPriednieks
If you set the page to a specific physical printer, then export to pdf, the drawing in the pdf file will be shifted. You must change the page print settings before exporting. For example, as tboehler suggests.
Message 20 of 36
What do I need to change it to?
I changed it to AutoCAD pdf and I get the same error that the left side and bottom are off the page. ANSI full bleed is selected as the apper size.
Fit to page and center the plot are not available.
