Pdf Import
Pdf Import
niall.rasmussen
Message 1 of 8
Pdf Import
niall.rasmussen
I currently use AutoCAD 2019; I regularly import Pdf files mainly drawings. In my Pdf import tab, I do not have Text Recognition and Text Settings available.
How can I avail of these extra options?
Regards
Niall
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
Show us what you see (and don't see) please: we don't know what you are looking at specifically.
And how do you know your PDF contains searchable text? Just as many have it as do not.
Can you search/edit/highlight text in your PDF viewer outside of AutoCAD? If yes, where do they show up, in the body of the text or in a side bookmark tab not related to it?
Message 3 of 8
cadffm
PDFIMPORT dialog never changed and there are no settings you are talking about!
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/AutoC...
Start command PDFSHXTEXT and switch to the settings, if that is what you looking for.
https://help.autodesk.com/view/ACD/2019/ENU/?guid=GUID-968085B7-1A5A-4C6E-9788-8CF0B40CAFD6
HTH
Sebastian
Message 4 of 8
niall.rasmussen
Hi, and thanks for your advice.
The commands PDIMPORT, PDFSHXTEXT & Combine Text are the commands in question. I have been looking at a tutorial about how to import a pdf, the text is usually separate individual items and how to join them together as a text group. You have to use the Pdf Text Recognition Settings Dialog Box.
I noticed that after you click Insert on the Menu Bar, then choose Pdf Insert, there also appears in the window, Recognize SHX Text, Recognition Settings and Combine Text.
How can I add this feature rather than having to type in each individual command?
Message 5 of 8
niall.rasmussen
After you import a Pdf file, the text is nearly always separate individual items, I want to add the commands to the Menu Bar that will allow you to join them together as a line text or a group text.
The commands are PDFIMPORT, PDFSHXTEXT & Combine Text
I don't want to type each individual command.
Message 6 of 8
pendean
Community Legend
Community Legend
@niall.rasmussen thanks for the extra information: sadly, what you want is not n option to add to any core command/popup.
Looks like you will have to look for or develop your own (or find a 3rd party) add-on that combines all features of the different commands into one. These customization forums may be where you will head over next to ask for help doing that https://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
Also look here to see if there is such an add-on already developed https://apps.autodesk.com/ACD/en/List/Search?isAppSearch=True&searchboxstore=ACD&facet=&collection=&...
Good luck.
Message 7 of 8
niall.rasmussen
Thanks to all who offered advice and help. 😉
Message 8 of 8
maratovich
Maybe this will help you - AutoImportCAD
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
