I currently use AutoCAD 2019; I regularly import Pdf files mainly drawings. In my Pdf import tab, I do not have Text Recognition and Text Settings available.
How can I avail of these extra options?
Regards
Niall
Show us what you see (and don't see) please: we don't know what you are looking at specifically.
And how do you know your PDF contains searchable text? Just as many have it as do not.
Can you search/edit/highlight text in your PDF viewer outside of AutoCAD? If yes, where do they show up, in the body of the text or in a side bookmark tab not related to it?
PDFIMPORT dialog never changed and there are no settings you are talking about!
Start command PDFSHXTEXT and switch to the settings, if that is what you looking for.
https://help.autodesk.com/view/ACD/2019/ENU/?guid=GUID-968085B7-1A5A-4C6E-9788-8CF0B40CAFD6
HTH
Sebastian
After you import a Pdf file, the text is nearly always separate individual items, I want to add the commands to the Menu Bar that will allow you to join them together as a line text or a group text.
The commands are PDFIMPORT, PDFSHXTEXT & Combine Text
I don't want to type each individual command.
Maybe this will help you - AutoImportCAD
