AutoCAD Forum
PDF does not show
7 REPLIES 7
Message 1 of 8
cb94030
8555 Views, 7 Replies
PDF does not show
I inserted a PDF image on my ACAD LT drawing, then send it to a colleague (both the CAD file and the PDF file).  When he opens the CAD file, the PDF does not appear on the drawing.
How do I fix this problem?
Thank you.
Chris
7 REPLIES 7
Message 2 of 8
cadffm
in reply to: cb94030
And he saved both files in a folder on his harddisc?
Which program (his)?
Sebastian
Message 3 of 8
jayhar
Hello @cb94030
Corrupt AutoCAD files, use Commend EXPORTTOAUTOCAD & insert PDF file, save to same folder location.
Two days before, my friend also have same issue.
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Revit Architecture Certified Professional
Thanks You
JAYHAR.M.J
Team Leader
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | AutoCAD randomly crashes or freezes
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Message 4 of 8
imadHabash
i suggest to try :
  • put both files ( CAD and PDF ) in the same folder.
  • let him after opening the CAD dwg file that you send repath the pdf file.
Imad Habash
Message 5 of 8
pendean
Have them drop both files in the same exact folder, restart their AutoCAD, and try again.
AND make sure they (and you) did not rename the PDF at all.
Message 6 of 8
cb94030
in reply to: pendean
- I have ACAD LT 2018.
- I sent my friend, both the PDF and CAD files to be placed in the same folder.
- Even though I "Imported" the PDF file into the CAD drawing, the "External Reference" window shows the  PDF file as a PNG image (?).
- I've done this with different files so it is not a case of a corrupted CAD file.
Any help will be appreciated.
Thank you.
Chris
Message 7 of 8
ChicagoLooper
@cb94030 wrote:
<..........I "Imported" the PDF file into the CAD drawing........>>
When you say 'I Imported the PDF file....' it's vague and could mean several different procedures.  Have you tried using the good ol' ATTACH command? You can access that command to attach your PDF (use Attach as opposed to Import) from the External References palette.
Chicagolooper
Message 8 of 8
cb94030
in reply to: ChicagoLooper
Thank you ChicagoLooper!!!
It worked with the "good old ATTACH command"
I appreciate your help!!
Chris B.
State of Sustainability Webinar
AutoCAD Inside the Factory
