Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
PC3 File Trouble
PC3 File Trouble
EBSPEAMD
PC3 File Trouble
EBSPEAMD
Somehow my Adobe PDF Converter disappeared.  Any ideas on where to look for it?  Using AutoCAD 2019.
pendean
Community Legend
Community Legend
Did you update your driver or change it or change AutoCAD?
Or use one of the other 3-4 PDF drivers that come with 2019 like DWG TO PDF.PC3
EBSPEAMD
Sorry about the late reply - things have been nuts.
Anyway - I have not updated my driver, changed it, or changed AutoCAD.  I've been fiddling since the error occurred but I can't seem to fix it.
pendean
Community Legend
Community Legend
The error message is pretty simply: the driver called "Adobe PDF Converter" is missing in action or the PC3 file is pointing to the wrong location looking for a driver.
Since 2019 comes with many additional stock PDF drivers you can easily test and use those instead why you figure out what happened to your other driver.
EBSPEAMD
Time to do some driver digging then.  Oh joy.  Thanks!
