Would AUTOCAD 2019 or 2020 work well and not slowly on a PC with the following specs?
Intel Core i7-10510U 1.8 GHz (Turbo: 4.9GHz) Quad Core
8Gb RAM
4Gb GPU - NVIDIA GeForce MX130
Thank you
Solved by natasha.l. Go to Solution.
Solved by pendean. Go to Solution.
For which file sizes and content? And it depends on how often and how long you work with AutoCAD each day.
Even if turbo goes up to 4.9GHz ... I always look to the default CPU clock rate to compare performance. 1.8GHz would be to low for average work.
I don't have experience with MX130, but looking to this comparision >>>click<<< you can see it's not the one with the most power. For systems with AutoCAD, used daily, mid or big drawings, 3D too, ... you should look to the values in this chart like GTX9xx or GTX1xxx
Just my 2c, - alfred -
thank you
I wont use it much - just for training and definitly not for big files as this will be a personal computer.
Thank you
I need a laptop.
Which specs do you reommend taking into account this will be a personal computer for training only.
Hello @Anonymous,
Thanks for posting in the community.
As @pendean mentioned please review the minimum system requirements for AutoCAD 2019 including Specialized Toolsets they should be adequate.
Please remember to "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community. Thank you. 😊
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
