PAT file for 3" x 24" herringbone custom hatch pattern
napletonn
Observer Observer
napletonn
Observer
Observer
I cannot figure out how to code a 3" x 24" herringbone pattern and would love some help!
pendean
Community Legend
Community Legend
Kent1Cooper
There are lots of herringbone patterns in the Customization Forum.  In a quick look, I found patterns of longer shapes than brick types in ratios of 5-to-1, and 6, and 10, and even 12, but didn't see anything with 8-to-1 proportions.  It could be defined at 3x24 directly, but could also be "generic" at 1x8, and you would use it at a scale factor of 3 [unless you're talking about one with double lines to show mortar or grout joint width].
It sounds like you've tried, which is good -- what do you have so far?
Kent Cooper, AIA
hugha
Try this:
; Written by HatchKit 4 Standard Edition
; HatchKit 4 Standard Edition (c)1990-2022 Cadro Pty Ltd
; www.hatchkit.com.au/
;-Date : 2022/05/17
;-Time : 13:38:08
;-HatchKit 4 Version : 4.3.0.3191
;-HatchKit 4 Output Filetype : AutoCAD®
*Herrigbone3x24,Herringbone
45,16.971,-16.971,3,3,27,-21
135,19.092,-19.092,-3,3,27,-21
hth,
Hugh Adamson
Kent1Cooper
Or, at orthogonal orientation to be used at 45° rotation if that's what you need, and without the weird origin numbers so you can place the origin at a meaningful location:
*Herringbone3x24
0, 0,0, 3,3, 27,-21
90, 3,0, 3,-3, 27,-21
Or, the "generic" version, at 1 drawing unit for the small dimension of the tiles [or whatever they represent], with an 8-to-1 tile-shape ratio, so you can use it with a scale factor of whatever you want the small dimenion to be [to get 2x16, 10x80, 4.5x36, etc.], without needing to do any relative-size calculations:
*Herringbone1x8
0, 0,0, 1,1, 9,-7
90, 1,0, 1,-1, 9,-7
Kent Cooper, AIA
hugha
Hi Kent,
The pattern is fit for purpose as it does place an instance of both pattern lines at the origin without translation.  Patterns are best viewed graphically rather than from within a text editor.
But I will concede a spelling mistake.
Always good to receive feedback. 😉
best,
Hugh
