parametric node - added measurements/ dimensions not parametric
hannes.randhahn
Message 1 of 10
hannes.randhahn
I experienced that my parametric drawing does not work well with my added measurements.
Changing the parameters of the drawing (angles, leghts) results in unalighned measurements.
Would there be any solution to properly lock and align the dimensions to the geometry?
see pictures attached.
Replies (9)
Message 2 of 10
Alfred.NESWADBA
can you please upload the dwg-file + a screenshot of command _ABOUT (the dialog content)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 10
S.Faris
You need to post the file here inorder for us to understand what parametric constraints have been used.
SALMANUL FARIS
Message 4 of 10
hannes.randhahn
Thanks for the quick response,
files attached.
Message 5 of 10
Alfred.NESWADBA
what do I have to do to see errors?
When I change the angle in your dynamic block from 80 to 60 or to 90, I get these results ... looks all well for me.
- alfred -
Alfred NESWADBA
Message 6 of 10
imadHabash
after opening your drawing , i think that you're NOT using any parametric dimensions !! i think you should check DIMASSOC (System Variable) = 2 .
Imad Habash
Message 7 of 10
hannes.randhahn
After checking DIMASSOC I found it was set to 2 before, so that did not help.
I still do not understand why just some dimensions are parametric.
As you can see in my model there is one vertical measurement off as soon as I change the node angle from 90 to 80 for example.
Message 8 of 10
hannes.randhahn
As you can see in my model there is one vertical measurement (also seen in your first screenshot) off as soon as I change the node angle from 90 to 80 for example.
I have another model where some other dimensions are off as well.
Message 9 of 10
Alfred.NESWADBA
Turn on ANNOMONITOR ... and you most probably see the reason (which dimensions don't have their assoc points fully assigned).
- alfred -
Alfred NESWADBA
Message 10 of 10
hannes.randhahn
Thanks, that really works.
Now I can reassign the measurement points.
Great work!
