AutoCAD Forum
Parametric Constraints stopped working
2 REPLIES 2
907 Views, 2 Replies
Working in AutoCAD 2021, my drawing is constrained completely. Previously I was able to alter the values of my Dimensional Constraint Parameters and the drawing would update. now, nothing happens and its like my constraints are no longer working when I make changes. I made sure the constraints were on, and inferred. I even tried deleting and resetting my constraints. its almost as if my drawing is corrupted and constraints no longer work in the file.
2 REPLIES 2
qnologi
mgalicki
in reply to: qnologi
Try to copy the guts of your drawing to a new file and see if it acts the same.
It may be your file is corrupt?
Everything in existence was first an Idea
Autodesk Plant 3D Premium 2019
Autodesk MEP 2019
HP 3.2 Ghz CPU 16 ram
1TB 7200 rpm SATA 6Gb/s hard drive
2GB DDR3 NVIDIA GeForce GTX 680ti
HP 2311x 23" LED Monitor
State of Sustainability Webinar
AutoCAD Inside the Factory
