Parabolic Reflectors
I am trying to make a solid that with a parabolic surface.
I plan to print a bunch or smallish parabolic surfaces with the intent of creating an array of parabolic mirrors to test the efficacy of a really inexpensive highly efficient solar heater. To do this I need to be able to vary the geometry of each parabola to have the axis and focus a bit different. I can create the mapping, the axis and focal point. What I can't seem to find is a means to create a square block with one side a parabolic surface in Autocad.
I understand the math but can't seem to figure out the mechanics of making it work with Autocad. I have Autocad Mechanical.
I will be grateful for any help.
Mike
SEANT61
Perhaps this unit size paraboloid surface can be of use.  With the proper scaling and CV manipulation, the surface can be tailored to size and focus - then used with the Slice command to shape a side of a Solid3d block.  See attachment.
See manipulation in screencast:
May your cursor always snap to the location intended.
Really neat!.  I am sure it will do what I need.
I haven't worked with surfaces in Autocad so I have quite a bit to learn.
Thanks for your help!
SEANT61
A surface is more easily manipulated.  Eventually that surface can either be "Thicken"ed into a solid or used with the Slice command to carve a recession into a solid.
elshawadfy
Hi @Anonymous,
There are a lot of types of paraboloids.. If what you want is as @SEANT61 drawn, a circular base paraboloid cut to have a square base - not smoothly transitioning to the square base - then all you need is to create a parabola following your equation and revolve it , then intersect it with a box.. I Assume you need to follow specific equations for the parabola at least, so here is what you need:
1- Creating the parabola:
     - You can use this lisp, and since you know the math  - you can deduce the start, end, and  the top vertex, which are what this lisp requires..
     - The parabola base should be >= the diagonal of the square (equal to be start the paraboloid exactly from the square corner)
     - The parabola height should be < the height used for intersection, to have the complete paraboloid..
2- Creating the circular paraboloid:
     - Trim the curve to half.
     - If you want the result to be a surface, Revolve the half curve directly 360 degrees..
     - If you want the result to be a 3D Solid, Create a Region first between the half curve and straight lines, then Revolve the region 360 degrees..
3- 3DRotate the paraboloids to make them vertical
       (Or you could have drawn the parabola in the front view in the first place - with UCS set to view of course)
4- Create a box,
      - The sides of the box base are equal, and each is <= the paraboloid base /sqrt(2) (see the 1st condition of the parabola)
      - The height of the box should be >= to the parabola or the paraboloid height
5- Move the box from center to the center of the bottom circle of the paraboloid..
6- Use "intersect" and select both the paraboloid and the box..
If what you need is a soft transition to the square so that all points of the surface meet the square base - that's a very different story, it can be achieved easily in modeling  - but the equations will be a hell to go through..
Dwg Attached..
Regards..
SEANT61
Nice work elshawadfy.
Now that this thread has come one more time, I realize the file attachment for my first post didn't make it online. May be late, but here it is anyway.
This is a real help.
I find the path from an idea to reality is strewn with shards of practicality.
An idea that stared on a bar napkin ( it really did) ended up with having to learn a lot of Autocad, the in's and outs of materials and 3D printing and the complexities of metal-plating of plastics.
I'm probably a few weeks to seeing first article. If it works, maybe I can make a gadget that will make power sufficiently cheap that folks in the bush can read at night. Maybe even make a phone call.
I thank you for your assistance.
Mike
