Paperspace paper background not aligning with extents
keithTZYB5
keithTZYB5
AutoCAD LT 2024
Hi All,
I repositioned my drawing border in Paper Space to 0,0. With the plot set up to extents, the plot was produced exactly as I expected with the border and drawing contents corectly positioned on the pdf. In the past when I have done this sort of thing, the background realigned with the extents as per the plotted output. However, recently the background has not realigned as in the screen grabs below and the attached cad file.
Is there a setting that controls this somewhere?
It is essentially a cosmetic problem as the drawing plots correctly, but it makes it difficult to work on with the areas that have the paper space background rather than the black background.
cadffm
"Paper" is just a helper feature for your eyes.. in this case because of unknown reason,  it is not up to date.
Do this: Change your Pagesetup
for example: Command PLOT, change plotscale to 1:2 [Apply]
and back again: 1:1 [Apply]
Sebastian
keithTZYB5
Thanks Sebastian - problem solved.
