- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This is an intermittent and ongoing problem. I have searched high and low for a solution with no success.
I am an AutoCAD power user since before R12 (...back to the DOS days, actually...).
Setup: I create 3D models and use varying layer colors to keep track of different parts while working in Model Space. When it comes time to plot a Paper Space layout to a PDF, I override layer colors in the Model Space Viewport so that all displayed entities will plot with black linework (index color 7):
Viewport Layer Color Overrides
The Paper Space Viewport now shows exactly what I want to see in the PDF to come (the red annotations are in Paper Space):
Viewport Overrides Display Correctly
Visual Style for the Viewport is set to 3D Hidden, and its Shade Plot is set to 3D Hidden. The Properties Panel also correctly indicates that the Viewport contains property overrides:
Viewport Property Settings
I plot to PDF using the AutoCAD-supplied acad.ctb Plot Style Table and a tailored version of the AutoCAD 2016 PDF .pc3 driver file:
Plot Dialog Settings
I do NOT wish to use the monochrome.ctb or any tailored "black.ctb" Plot Style Table.
The resulting PDF does not show the effect of the color overrides:
Resulting PDF Does NOT Show Color Overrides
Note the colors of the drawer boxes (green), the small control panel (orange), and various hardware items (dark red), all of which are plotted with their respective layer colors, and all of which layer colors were set to override to "White" (index color 7) that should have plotted as black lines, just like the rest of the elements on Layer 0.
I have gone through every setting I know of that could reasonably affect plot-to-PDF functionality, and am at my wit's end! The truly frustrating thing about this problem is that is is NOT consistent across new and/or reused drawing files. Some days the color overrides work. Some days (...this being one of them...) they do not. I cannot find a single setting or set of settings that are clearly different from one working instance to another not-working instance and might thereby point toward a solution.
Here is my AutoCAD version info:
Any help will be most appreciated!
Best regards,
James Gafford
Omnirax Furniture Company
