Paper Space Dimensions Slightly Off
luikertc
luikertc
My dimensions in model space are 100% correct and are reading correctly with the distance command. When I am in paper space, some dimensions will read correctly and some will read at like 1-3/4" off. I have made sure I am clicking the correct points and even made sure my lines were drawn straight. My units are also the correct units. What should I do to fix this issue?
akhtar4223
Share the affected drawing to understand your problem
imadHabash
You may have some annotative dimensions .. you can post here a CAD dwg sample for testing ?
Imad Habash
Valentin_CAD
@luikertc ,
Consider the suggestions in this link: Newly drawn dimension shows the wrong value in AutoCAD
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
illusionistNUGXG
Hmmm just to be sure...
1. Is it precicely correct? Try a higer value of LUPREC and meassure again, to see if it is slightly off.
2. Could it be that the objects are elevated? Is everything at Z = 0?
luikertc
The problem was my LUPREC was too high. I had it at 8 and when I was printing to scale everything was about a foot off. When I changed it to 7 everything is printing normally. Thank you!!
