@DM2-fire,
I would welcome the feedback of others, but my experience has been that an LTSCALE value that works in modelspace (MS) may not work in paperspace (PS). Often you must change the value when you are working in MS and then switch to the alternate value for working in PS.
For example, you may have LTSCALE = 2 in MS, then switch the value to 0.5 when in PS.
Maybe there is new workflow I am not aware of, but that is how I have used LTSCALE when working with MS/PS.
I also noticed that you are using linetype scale overrides on many of the objects. This may add complexity when calculating your LTSCALE values for MS/PS.
I recall a LISP utility a while back that would automatically switch the LTSCALE value when you switched between MS/PS.
Again, I welcome the feedback of others.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
