Announcements
Pan with right mouse button.
how can I set up right button for PAN instead of the middle one? Thanks for your answer.
mouse controls should be located under tools tab...  then customize... then interface....  in there you should find the mouse settings...
nrz13
That setting will need to be customized in your mouse driver software, if that is an available option.  For instance, Logitech's SetPoint software allows many custom configurations that can either be applied to all programs or specific programs, such as AutoCAD.  On my version of SetPoint with my mouse, I'm still unable to customize the left or right buttons, though.  A quick Google search for "customizable mouse driver" returned this.  You might give it a shot or try looking for other customizable drivers for your mouse.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
cameronbehning
Observer
Observer
Is there no way in AutoCAD (not using a work around with mouse drivers) so change this setting? MMB as pan makes track pad usage impossible.
pendean
Community Legend
Community Legend
@cameronbehning wrote:
...MMB as pan makes track pad usage impossible.
Trackpad? Which one and driver version are you using?
