mouse button customization for PAN command
Message 1 of 13
Hello All,
I am a long time autoCAD user. Since 2002...
I was using microstation for about 1.5years at a firm I was working for, and have recently switched back to AutoCAD.
I customized the mouse buttons so that the when I clicked and held down both the LEFT, and RIGHT mouse buttons I would PAN the model space.
I can't seem to figure out how to customize this in AutoCAD, it was rather simple in microstation.
How can I change the PAN command from my scroll clicker, to a LEFT and RIGHT click combination button?
I'm using a Logitech M705.
Perhaps this is the problem.
Solutions are appreciated!
Replies (12)
Message 2 of 13
pendean
Community Legend
Community Legend
You don't in AutoCAD: your mouse driver must offer options for you to do what you wish. Most don't.
So which mouse and which driver is in use on your PC?
Message 3 of 13
GrantsPirate
You can pan by holding the intelliwheel down, no need to customize.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 4 of 13
pendean
Community Legend
Community Legend
OP already noted he doesn't want that option.
Message 5 of 13
GrantsPirate
I wasn't sure what a "scroll clicker" meant in the OP.
GrantsPirate
EXPERT ELITE MEMBER
Message 6 of 13
BrianBenton
AutoCAD won't let you click two mouse buttons at the same time. You can click, shift+click, CTRL+Click, and CTRL+SHIFT+Click.
If you open the CUI (type CUI on the command line) go to the Customize tab and scroll down to the Mouse Buttons options, you can customize your clicks there.
Brian C. Benton
bbenton@cad-a-blog.com
http://CAD-a-Blog.com
twitter.com/bcbenton
www.facebook.com/CADaBlog
Message 7 of 13
thanks for the reply, cadablog.
That make sense, but also unfortunate. Having the ability to keep both the index and middle fingers on the click buttoms without having to remove them to pan was super comfortable.
If I'm able to set this up through my mouse configuration I will post an update!
Message 8 of 13
BrianBenton
I understand completely. your fingers have muscle memory and they are use to working that way and want to continue. Logitech has a great customization driver, of course I can't remember the name of it right now. Go to their website you might be able to find it.
This weekend I started using 3Dconnexion's brand new CadMouse. It has three "click" button, of which, the middle click button acts like clicking the scroll wheel. That might be the mouse for you. Visit their site and check it out.
Brian C. Benton
Message 9 of 13
Apologies for unearthing an old thread.
I too like the OP would like to change the pan function on the mouse, but simply to dragging right mouse button as per other software package.
Curiously, a previous poster suggested this may not be possible within AutoCAD, something to do with the mouse drivers, but I'm hoping this isn't the case!
Any help would be highly appreciated!
Message 10 of 13
elshawadfy
Hi @Anonymous,
To pan with your left mouse button, just hit "p" & enter, and use the left mouse button..
Message 11 of 13
RobDraw
It is the case. You need a mouse with programmable buttons.
Rob
Message 12 of 13
cameronbehning
Observer
Observer
When I go to CUI, button 2 (RMB) and button 3 (MMB) are set to "grips menu" and "snap Menu" respectively, but that's not what they actually do. How do you set the RMB to pan instead of MMB?
Message 13 of 13
pendean
Community Legend
Community Legend
@cameronbehning wrote:
...button 2 (RMB) and button 3 (MMB) are set to "grips menu" and "snap Menu" respectively, but that's not what they actually do...
They do actually, under the correct program parameters/circumstances only, not when you press those buttons outside of those triggers.
Which mouse and mouse driver combo are you using exactly please?
