AutoCAD Forum
Page Setup Override to (1) file
3 REPLIES 3
jwylie2020
465 Views, 3 Replies
jwylie2020
For years I have tried to use Publish using page setup override in the sheet set manager to make 1 pdf of all sheets.
All works fine if PUBLISHCOLLATE is set to 0 (1 page per pdf file)
If PUBLISHCOLLATE is set to 1 (1 pdf file for multiple pages) an error is immediately found with the first page "ERROR: Device not found"
Printing to pdf works fine when only publishing ... overrides is for one sheet and PUBLISHCOLLATE set to 1.
This is all using the DWG to PDF.pc3 printer.
Has anyone else had this problem and fixed it?
John W
JL
C3D 2024
Win 11 Pro
John W
JL
C3D 2024
Win 11 Pro
Labels (4)
3 REPLIES 3
cheryl.buck
in reply to: jwylie2020
cheryl.buck
Autodesk Support
Autodesk Support
Hi @jwylie2020,
I found this article in the Autodesk Knowledge Network (AKN) relating to the error you mentioned:
"Device not found" when publishing in AutoCAD
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Hi @jwylie2020,
All the best,
Cheryl Buck
jggerth
jggerth
If you are running a relatively current version of AutoCAD, change your PageSetups to use the current "AutoCAD  PDF (General Documentation).pc3" device instead of the older "DWG tp PDF.pc3" plotter.
jwylie2020
in reply to: jggerth
jwylie2020
Thank you. This worked great.
-John
JL
C3D 2024
Win 11 Pro
-John
JL
C3D 2024
Win 11 Pro
AutoCAD Inside the Factory
