Are there any standard layers for P&IDs? If so, where can I find them. I'm having a difficult time finding anything.
Thanks.
Solved by TheCADnoob. Go to Solution.
Solved by lbellino4. Go to Solution.
From what I read, if you're using ACAD P&ID, it comes with it's own layers, but you can create your own standard layers, when you create a template drawing, if you want. Where I work, we use regular ACAD and we create our own template drawing with the standard layers we want to use and this was determined from our internal group of designers that work in these drawings daily. I don't believe there are set layers like there are for architectural drawings.
This is my problem. The company I work for is not used to doing P&IDs, so they have no standard. I'm stationed at a customers site and this plant runs off their P&IDs. Problem, these layers tell me nothing. Let me put it this way, some of these drawings have not been touched in over 10 years. So, I basically starting from scratch.
Can you post an image of the layers/names? I'm curious how they were named and if I've seen something similar from jobs I've worked on.
They are MicroStation layers from 10 years ago. They are mostly numbers, lol. I have my work cut out for me.
Sounds like you're going to need to create the template with the layer names you want to use going forward from project to project. Below is an example of some of the layers we use in projects, but most of our projects are for the food industry.
Thank you. We make soap. I appreciate your help. This will at least give me a baseline.
@nillisa2000 wrote:Are there any standard layers for P&IDs?...
May I ask, are you just the "cad guy" trying to turn paper into not-paper, or are you specifically P&ID trained and equipped with a full library of content? And are you trying to do all of this in plain AutoCAD?
No reason not to use AutoCADPlant3D (free for subscribers to install and use) if the client is trying to do more than just transfer paper (or old system) to paper-like plain AutoCAD content, read more here
and
https://help.autodesk.com/view/PLNT3D/2024/ENU/?guid=GUID-DD6C24E7-0136-4051-8346-22A970F4C93A
then
https://www.autodesk.com/solutions/pid-software
Continue the discussion in that forum if you decide to go there, here is one of many on the topic for once you get into creating content:
Note: P&ID tend to have more strict requirements for layers, and limited ones to start with:
Equipment
Existing Process
Instrument
Instrument Lines
Mechanical Process
Text
HTH
I've worked for both owner-operators and engineering service providers regarding P&IDs. I've seen them broken out by service, size, location, etc., In other words, there isn't necessarily a wrong way to do it, but at the end of the day, I think the biggest thing to be mindful of is the P&ID symbology.
PIP PIC001 is a common standard in Process Piping (i dont think it has a layering component), but there are usually proprietary (regarding the facility designer) standards that are also followed. Who ever designed your process probably had a decent enough layering standard. I would just adopt thiers.
If you want to create your own layers, some options are to have equipment on a layer, vales on a layer, revision clouds on a layer, and Process lines on a layer. It really comes down to how the documents are used.
It quite often that we circuitized P&IDs meaning we create special layers for different needs that follow the same paths as the lines. An example would be in older plants they will have lines on the P&ID that have asbestos mitigation requirements. Showing those indications on a P&ID aren't necessarily part of the intended function of the P&ID qua P&IDs but its very help when it comes to planning. I have also seen circiuitization used for making down lines for inspection and maintenance and reliability. This is usually the biggest use of layers that I've seen in P&IDs.
I also second the use of Plant 3D. It has the some really good out of the box tools for P&IDs.
CADnoob
