Overlapping Superhatch
Hi all,
I am working on a project in autocad 2D where I need to show furniture layout with floor plan. I have drawn the furniture and to give a realistic look used Superhatch command to fill the furniture drawing with real furniture images (fabric or wood) taken from internet. I am also trying to Superhatch the floor with an image of wooden flooring. But the problem I am facing is when I try to place the Superhatch furniture on the Superhatch floor, the furniture Superhatch becomes invisible n overlapped by floor Superhacth. I have tried to make blocks also and used the commands like bring above object etc, but nothing seems to be working.
Please guide me what to do.
vinodkl
I am able to overlap two objects with superhatch with no problem on my end. Can you again give it try using the command "DRAWORDER" and use the option "front" to get the furniture to the front? If it still doesn't work then post your drawing so that we can test from our end.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Hi
Thanks for you reply but I am still unable to do this. Please refer the below image. The circle with grey colour superhatch is changing when i try to move it on the superhatch floor. The circle is still visible but not with the same superhatch colour as shown in the circle given outside.
I have use draworder command, send to back, bring to front and all other options but no luck.
kindly advise.
R_Tweed
If your circle is a block I would add a wipeout and then change draw order. The block shown is attached but am not sure if the images will follow.
