I'm trying to find out a way in which I can easily identify any overlapping closed polylines.
I have approximately 250 closed polylines very close to each other but without zooming in on each corner (very time consuming) I can't see if they overlap.
Is there a more efficient way to do this through a command or a lisp tool?
Many thanks
@j.straughan wrote:
... identify any overlapping closed polylines. ....
That may depend on what you mean by "overlapping." Does coinciding count [red, left -- portions of edges overlap], or do you mean only crossing [green, right -- enclosed areas overlap]?
EDIT: Or, the variant on the left condition: a vertex of one touches another [whether at a vertex or along an edge], but with no length of overlap of edges?
I tried to use that but couldn't get the lisp to work? I loaded it into AutoCAD but couldn't find out what to type in order to use the lisp? Could you please advise on that?
It would be mostly intersecting like shown on the right but in some fewer instances the lines may be coinciding like on the left.
>Here< is something about that. But it's for selecting two of them. [You can find other related threads in the Customization Forum with a Search for things like "find overlapping Polylines," some of which (like that one) find touching and/or coinciding edges and some only area overlap.]
The linked routine from Lee Mac uses the same basic function to find the intersections, but takes multiple object selection and does the marking of them. I think you want the variation called "Intersections in Set." You would need to load the LM:intersectionsinset code there, and the "Test Program" below, and the LM:intersections code at the top of the page. Then use the "interset" command name defined in the Test Program.
Thanks that is very useful.
With the Lee Mac one, do I load the three things you mentioned all as lisps and then use interset?
Thanks.
@j.straughan - you will need the first two functions below as a minimum. The last one is an example of their usage.
LM:intersections
interset
Do you mean overlapping polylines or overlapping segments inside the individual polylines? The SelfIntersect utility (freeware) may help for the latter problem. See:
Vladimir Michl, www.cadstudio.cz
