OVERKILL lines deleted
jdfnnl
jdfnnl
There are a lot of posts about OVERKILL not working but this is to ask how I can see what objects found to delete. I have a large drawing in which the command deleted 25 lines overlapping lines while not ignoring layer, linetype and linetype scale. Is there a way that I can isolate those lines to verify nothing crucial was lost?
Valentin_CAD
@jdfnnl ,
The OVERKILL command does not offer this option.
It would be nice if the duplicate or overlapping elements could be "isolated" or put on a "deleted layer", but this option does not exist - that I'm aware.  Your best option is to keep a copy or back-up of the drawing before applying the command.
Use Product feedback to tell Autodesk what you think about its products and any improvements you'd like to see.
You can also complete your suggestion on the Autodesk User Group International (AUGI) wish list - LINK.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
