I have used the list function on Autocad for years and only recently has the output of the list function, namely the coordinate list (at point X=000.000, Y=000.000, Z=000.000), seemed to change. When using 'list' I want the coordinates to appear in a list like fashion as they previously would.
As it stands, I get the below mess, but I don't know what's changed that has altered my output.
Any help appreciated.
Solved by matthew_foxAR48D. Go to Solution.
I can't test it now, but if nothing changed in this version, there is something special on your side.
Is it the same in
1. Expand docked Commandline [ctrl+9]
2. Textscreen [F2]
and
3. LOGFILE
And wth is a "LWPOLYLIN" ??
I miss one "E" !
Hmm. Restart tested?
Sebastian
Your screenshot
Mine (with an E) and well organized
I wonder if you just need to restart your PC.
Does this strange listing format only happen on this particular drawing or on all drawings?
Yes, that's the list I'm familiar with.
Unfortunately, it's the next day - complete reset with PC - and still the same issue.
I've opened a brand new drawing and still the same issue.
Solved:
used command SYSVARMONITOR. DYNMODE was set to -2. Reset all values and all seems to be working now.
Thanks all
It always fascinates me when you fix the broken door by opening a window.
Was Dynmode the only variable what was on another value than your fav values?
Because Dynmode value has nothing to do with your issue, usually not.
Please change it back to -2 and test it again, thx.
Does the isse reappear?
>"seemed to change"
Do you have a new installation or have you been using it for a while and the list was already working properly up to this point?
If it is a new installation: Did you use the settings migration from an older version?
I actually only know such funny problems when you use add-ons or data migration.
Sebastian
So the issue occurs on other drawings, until I perform this botched fix.
[screenshot of command log]
Initial input 'LIST' - DYNMODE <2> - LIST - SYSVARMONITOR (Reset value.. screenshot below) - LIST... Solved?
It's beyond my knowledge, but it seems to work so I'm running with it.
>>"So the issue occurs on other drawings, until I perform this botched fix."
Does it mean:
1. you reset the list one time and after you open another file, Dynmode changed to another Value?
2. And if you type in
Command: DYNMODE<>enter1<enter>
it doesn't solve the issue?
3. but after reset the sysvarmonitor-list, it works (and dynmode is still on 1)
4. and after you open another file, dynmode ist again set to another value?
Sebastian
Did you make this setting change?
If you run LIST with dot .LIST, does it make a difference?
