Osnap box snaps to a ghost point!! 2015/2014LT
I have a file done in Civil3D from a surveyor. Ill call this file SURVEY.
Created a new file, in 2015LT, called BASE, and xrefed SURVEY inserted at 0,0.
Created another new file called DEMO, and xrefed BASE, inserted at 0,0 (with the nested SURVEY file).
In the DEMO file, when I snap to an endpoint of an object, the snap box finds an endpoint that is 5 ft off
from the actual endpoint of the object. It snaps to a location where there is no object (on screen) but it is telling me,
this is the endpoint. It does this for center, mid, intersection, etc.
This only happesn when snapping to an xref'd object...not newly drawn objects in the DEMO file...and happens in paper and model.
This does not happen in the BASE file, nor the SURVEY file. It happens on other computers in 2014 and 2015LT.
It is kinda hard to draw a line to an actual object point visually, without the osnap. What could be causing this?
Patchy
Try OSNAPZ
if it doesn't work, ETRANSMIT and post your zip file.
Patchy
Use World UCS, most likely UCS got rotated as seen here when snap to endpoint.
undefined
The UCS was reset to World with no change.
Turns out the Units was set to inches (unknowingly)..should be feet. When the xref was inserted had to scale the xref by a factor of 0.083
Well, if you put too many 3's in there it changes the the scale slightly.
Autocad was snapping to a coordinate in the xref, that was different then the coordinate in Model space, so it was not snapping to
the object endpoint on screen.
Thank you for your reply.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
