Ошибка установки
Ошибка установки
Ошибка установки
2018/12/27:17:56:51 Admin DESKTOP-FM2SMNL === Setup started on DESKTOP-FM2SMNL by Admin ===
2018/12/27:17:56:51 Admin DESKTOP-FM2SMNL Path_Length: 158
2018/12/27:17:56:51 Admin DESKTOP-FM2SMNL Current Directory C:\Autodesk\AutoCAD_2018_Russian_Win_64bit_r1_dlm
2018/12/27:17:56:51 Admin DESKTOP-FM2SMNL Launch
2018/12/27:17:56:51 Admin DESKTOP-FM2SMNL CommandLine
2018/12/27:17:56:51 Admin DESKTOP-FM2SMNL Current Directory C:\Users\Admin\AppData\Local\Temp\_AIBCC5.tmp
2018/12/27:17:57:51 Admin DESKTOP-FM2SMNL === Setup ended ===
2018/12/27:17:57:05 Admin DESKTOP-FM2SMNL === Setup started on DESKTOP-FM2SMNL by Admin ===
2018/12/27:17:57:05 Admin DESKTOP-FM2SMNL Path_Length: 158
2018/12/27:17:57:05 Admin DESKTOP-FM2SMNL Current Directory C:\Users\Admin\AppData\Local\Temp\_AIBCC5.tmp
2018/12/27:17:57:05 Admin DESKTOP-FM2SMNL Launch
2018/12/27:17:57:07 Admin DESKTOP-FM2SMNL Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Admin\AppData\Local\Temp\_AIBCC5.tmp\Setup\AcSetup.dll
2018/12/27:17:57:07 Admin DESKTOP-FM2SMNL Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/12/27:17:57:37 Admin DESKTOP-FM2SMNL PageOpen LaunchDialog
2018/12/27:17:59:10 Admin DESKTOP-FM2SMNL PageOpen LicenseDialog
2018/12/27:17:59:14 Admin DESKTOP-FM2SMNL PageOpen ProductInfoDialog
2018/12/27:17:59:14 Admin DESKTOP-FM2SMNL PageOpen ProductSelectionDialog2
2018/12/27:17:59:21 Admin DESKTOP-FM2SMNL PageOpen FullProgressDialog
2018/12/27:17:59:21 Admin DESKTOP-FM2SMNL Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_2018_Russian_Win_64bit_r1_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2018/12/27:17:59:29 Admin DESKTOP-FM2SMNL Microsoft Visual C++ 2008 SP1 Redistributable (x86) return code: 1618
2018/12/27:17:59:29 Admin DESKTOP-FM2SMNL Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
Alfred.NESWADBA
it looks like VC++ redist 2008 could not be installed, either because of internal Windows conflicts or permission issues.
Please login as administrator, then turn off antivirus software, next uninstall and reinstall the C++ redist's as described here >>>click<<<
AutoCAD should then be installed fine ... my preferred method is to use "Browser Download" for installation (>>>details<<<), I do not recommend the install from www.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
